Got my car back this afternoon - it was finished yesterday but I was in work.
Seems to be back to normal, nothing untoward. From discussion with the mechanic it was the bolt on the injector clamp that had slacked back.
Thanks for the advice on the board. Much appreciated!!!
Excellent...Thanks for letting us know the outcome.
  • 3 years later...
Hi Damian,
I have got exactly mthe same problem that you are describing.
Did you manage to fix it please? What had to be done?
Peter
7 hours ago, peter.ling24@gmail.com said:
Hi Damian,
Peter
Hi Peter
Basically the injector is held in place by a v shaped clamp that is torqued down with a lock nut and held in place.
So the rocket cover needs to be removed along with all of the fuel lines, glow plug and cabling, to get access to the injectors.
Once in the the v shaped clamp should be replaced and torqued back into place, then the whole top end reassembled
It's a good idea to check the other clamps when it's all opened up as well.
The engine oil that was leading out is used to cool the injectors. Once the injector is back in place the oil leak drops too. The rocket cover gasket should also be replaced.
Hope this helps.
D
Hi Damian,
Thanks for replying. It is very helpful. I'll let you know how I get on.
Peter
  • 2 years later...
hi as i used to own a 2012 toyota avensis 2,0 D-4D i replaced 8 injecters on it has 267.000 kms on the clock
  • 7 months later...
Hi
Problem with Injector #4 feedback volume 5.0 mm3/st changed injector, switched number 3 injector with number 4 , when switched no change in #4 feedback vol still 5.0
Any
Ideas
Much obliged John - I left it round with my technician today - the information I arrived was of help.
Regards,
2nd hand engine
Hi,I have 07 aurus diesel 2litre ,when taking off in first,then second,car takes time in building up speed,acceleration delayed but after a few seconds speed is met,black smoke from exhaust, had services, nothing came up on diagnostic,all filters changed,oil,ect thought of map sensor or lambard sensor,but Sony know enough, can anyone advise please
