Hi dudes.
I,ve got some wheel spacers knocking about in the garage. (two pairs)
They bolt on between the wheel & the hub so I assume I need longer wheel studs to compensate for the extra thickness.
The spacers are 5mm and 10mm thick.
Just wondered if you guys knew of anywhere I could buy the studs I need to bolt these babys on???
I,m hoping to fit the 10mm spacers on the rear wheels.
Are they H&R spacers? Should be able to get studs from the people you purchased them from. :thumbsup:
Not sure where they came from to be honest, think they were off one of my sons cars and cant find any makers marks on them.
Do you think a place like Halfords would supply longer studs/bolts?
