Shell V Power - Unleaded
The Game
Hi , got a 2006 toyota yaris t3 1.3 , today went to Shell petrol station and put 50 pounds e5 vpower and went from driver about 14mint to get to work and it starts to pull less power and sometimes drives fine, also can anyone on here has the same problem?
Also I no I had 2 bar left and I did had BP petrol in and then I full tank Shell e5 vpower petrol,, do you think because it mix with other fuel? Because I no I had 1lit toyota yaris 2006 with no problem at all with Shell e5 with mix with other fuel
  • Sad 2
54 minutes ago, maz78600 said:
Hi , got a 2006 toyota yaris t3 1.3 , today went to shell petrol station and put 50 pounds e5 vpower and went from driver about 14mint to get to work and it starts to pull less power and sometimes drives fine, also can anyone on here has the same problem?
Also I no I had 2 bar left and I did had BP petrol in and then I full tank shell e5 vpower petrol,, do you think because it mix with other fuel? Because I no I had 1lit toyota yaris 2006 with no problem at all with shell e5 with mix with other fuel
It seems you had filled up with bad quality petrol, best to avoid this garage in the future. I had similar experience previously from another garage, filled up premium fuel and the car became almost impossible to drive. Engine started to work bad, lost power and when tried to switch off ignition the engine often continued to idle, very bad petrol. If the fuel is good quality you can mix any type petrol without any problems. What you can do now is to buy petrol injectors cleaner and add to the tank and drive as usual per your needs to finish the tank and refill at other place, e5 or e10 , it doesn’t matter, e5 is the better petrol by default and every engine on any car will work better on it , but if the fuel itself os rubbish like in your case then there is nothing you do about it.
Good luck
