Celica Gen 6 Rear Wheel Bearing Or Complete Hubs?
h4rfang
Hi I have a 6th generation celica ST (1.8l 4cyl) and the rear bearing is broken ... after having sought the rear bearing on the internet I am unable to find the right piece for my celica ...
my question is: Is what I am forced to buy the complete hub assembly? ... $ 425 :( Or it is possible to change the bearing alone?
after looking at the hub I noticed it came with the speed sensor rotor (i have ABS but It do not work anymore anyway) is that the model without ABS possesses the same type of hubs?
If it is possible to put the single bearing or the hubs without ABS ... Is that someone could give me the part number or a link to get it on the internet?
A BIG THANK YOU!
  • 4 weeks later...
A BIG THANK YOU!
Were you able to replace your wheel hub bearing? I also found a similar part but it comes with ABS and I'm not sure if I can just take that off. Hope somebody can also help give some tips on how to replace just the bearing and not the hub since there's really a big difference in price. Thanks.
Hi There, I have changed my hub & bearings on the rear of my ST202. They come as a unit so they do not split.
If you have ABS (like I do) they cost alot more than the import parts.
Its quite striaght forward though. After you have taken off the wheel, brake caliper your faced with 4 nuts... Take off then replace...
Took me about 1'n'half hours to do the full job...
A BIG THANK YOU!
