Help
qubec
hi im a new member, i have an avensis d4d t3x 2.2 deisel. my engine managment light,trc light,vsc lights,have all come on whith engine running....any advice appreciated.
Hi mate,
you could try disconnecting the Battery (just the negative terminal will do) for a few minutes then reconnect and see if the fault clears, if not you need to get a garage to plug in a code reader to see what fault code shows up. See Peanutome's post started on May 17th in regards to Battery disconnect if you have any worries about doing it, this post is still current and has some good advice from the answers.
Regards Pete.
Hi mate,
Regards Pete.
thanks pete i,ll give that a try. terry
