Which Way?
briggadoonred
when I got my aygo blue I was told by the salesperson to leave the key in the lock and turn anticlockwise to undo the cap,now Iv'e been told to turn the key 45deg.anti clock and then back to the middle and remove the key,as I have not yet put any petrol in the car yet which way is correct?
As the salesperson said, 45 degrees anti clock to remove the cap and back to the middle when you want to remove the key. :)
The problem is of course, that the Aygo uses so little petrol that you forget how to fill it up when it does actually need some gogo juice!!! :thumbsup:
The problem is of course, that the Aygo uses so little petrol that you forget how to fill it up when it does actually need some gogo juice!!! thumbsup.gif
Brilliant reply :lol2:
