Heater Blower Fan
carday
Hi looking at these forums it seems that my heater blower fan has had its day as it no longer works, someone said it may be just blocked with debris and could be removed for inspection. Question is how easy is it to take this out and what would I be looking for.
If anything is blocked it will be the pollen filter. To remove this,open the passenger door and glove box. Remove the phillips headed screw on the damper arm visible from the door side. Squeeze the two inner sides of the glove box until it can drop out and down. The filter cover can be seen, release the catches at the sides and remove the cover and then filter.
Fitter
Fitter
It's not the filter, this has been changed. The fan doesn't work at all
