4.1 Pollen Filters
Antiquary
Are there any pollen filters hiding in a 1994 RAV 4.1
It's a bit smelly when air con is running.
You have aircon :eek:
No but you can still get smells. Try an anti-bacteria kit which will improve things.
Terribly posh!
Thank you. Not sure where to apply it though.
Car is called 'Pongo' nothing to do with being cute though :(
turn the engine on and then the aircon and fans..
then spray 8 cans of odour eater of your choice into the air intakes
Leave the car for 6 days unless you want to become asthmatic following fume inhalation.
Or you can buy an ozone generator which kills stubborn smells, plants and goldfish. So if an infestation of goldfish is yer problem, then its solved. Will also kill off the dandelions growing from the windscreen.
