It looks as though the radiator on my 1997 1.8 GS Carina E needs to be replaced. I'll check the scrappy and online for a bargain, but is it as easy as draining it, removing hoses, unbolting and replacing then doing everthing in reverse? Is there more to it - it looks straight forward enough, but I'm not that great mechanically.
hello mate
there must be a drain plugs (hexagon head type) on the one/two cyl block sides. Be sure before you have them unscrewed an expansion tank lid is removed. The hoses can be easy to remove by releasing of hoses bands. Cheers Igor
It's not hard at all mate.
eBay is your friend here. Is this the right one?: Carina E Radiator
Just check eBay they'll have something!
Thanks Guys - all sorted and going well. As a bonus unclipping the front O2 sensor and plugging it back in again cleared the warning light that has been on for 18 months!
Cheers
Ian
Cool, glad you have it sorted now. :yes::thumbsup:
No problem!
