Engine Management Light
AndyG80
Hi All,
This is my first post, I have a problem with my Celica, Its an '02 plate and done 92k miles, just recently the engine management light has been coming on when i accelerate over 6000RPM, I thought it may be air filter sensor and cleaned that, removed Battery and the light went away. Last night i tested it and the light came back on and i have noticed also that it does not give you that extra 'kick' that it used to now either,
does anyone have any ideas/suggestions
Thanks in advance
Andy
could be that the lift bolts have snapped.????
Thanks, i will check that first and see if it is that
Andy
your management light is on so get a diagnostic check carried out, see what fault code is been triggered, you should be able to work it out from there.
