Celica 94 Lambda Sensor
ali1605
Hi all was wondering if anybody could help me,,,, need to change the lambda sensor on my celica 94 import, but having trouble with companys sending me the wrong part and as I cant get the old one off at the moment I cant give them a part no, also how many sensors does a celica have? I have been told 2, one on the manifold and one on the exhaust but have only found the one on the exhaust before cat, If anybody could help I would be most greatfull, dont want to take it to the gargage cos they want abit more money than i am willing to pay, Many thanks.
which engine ???
which engine ???
3S-GE, 2.0L automatic,
first thing is to check how many wires its got , the 1 you need is under the car , id suspect its got 4 wires , you have a few options here - fit a universal sensor , goto toyota and buy the original or try these 2 places -- http://www.tcbparts.co.uk/ Celica ST202 (1995 -onwards) 2.0 3S-GE engine
Lambda Sensor ( screw in type) Genuine Toyota
Part number: 89465-20490
Price: £138.82 + vat
this may be the one for your car . you'd need to call to confirm
or try these guys who list 3sge sensors for the mr2 but its the same engine http://www.justlambda.co.uk/ single wire = £46 4 wire = £55 .
universal 1 wire = £40 universal 4 wire = £50 ,, you'd need to call again to confirm fitment .
lots of other places online if you google lambda sensors = http://www.worldcarparts.co.uk/Default.aspx?TabId=144&ProductID=1314 . or maybe even try these guys £35 on eBay http://cgi.ebay.co.uk/NEW-Direct-fit-TOYOTA-Celica-Oxygen-Lambda-O2-Sensor-/250452044890?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a501aec5a hope this helps .
which engine ???
Hi Thanks for your help, The lambda sensor that is on the car is screwed in by two bolts, this is the one I keep trying to order but keep getting the wrong one sent, A gargage has quoted me nearly £500 for them to do it and I think that is way too much, I cant find a part no one it so that I can give that, it is starting to get abit annoying,
some are screwed into the 2 bolt plate ,the plate comes with the sensor or its a part of the actual sensor housing, you would need to check this also , advise lashings of wd40 on it cold before trying to remove bolts otherwise they snap in place. my advise would be to call a dealership , give them your vin plate and ask question them what part number it is , they sometimes with hold this info , but some give it , if you pm me the full chassis , frame , vin numbers i can take a look on the toyota epc for you , but id need all the numbers from the vin plate .
ps - £500 is taking the mickey as its a 10 minute job to replace .
