Converting Fog Light To Day Running Light, Wiring Help Needed
Avensis 1999
Hi All,
One idea is to use a jumper wire from the 10a Ignition Fuse connected to the 15a Fog Light Fuse under the dashboard, which i'm hoping will activate the fogs when ignition is switched on.
Then use a relay connected to the Headlight Loom under the bonnet to switch the Fog Light Wire on/off.
Does anyone know if this is ok to do, or do you have a better idea ??
Thanks in advance.
Ive found the answer, no need to reply !!!
Moderators feel free to delete this Topic.
Please do not delete this thread as I would like to be told of your solution to the issue.... would you care to share how you completed the work as I might consider doing the same if it is easy enough yes.gif
