Need Complete New Aerial Base - Help!
Hudders
Have had an incident with a hand car wash and my aerial.
I came of worse and need replacement base / footer.
I needs to be accessed from inside the the car.
Please can anyone advise re a suitable replacement.
Not sure if need a genuine part.
Open to any suggestions
Amanda
Amanda
hi hudders
have seen sharks fin replacement aerial advertised that covers the oringnal base.
you may be able to get around the problem that way without having to strp things out to put in ome.
will see if i can find an adress for you.
Amanda
hi again amanda
have been on eBay and loads shark fin aerials self adhesive some are for auris. choice of colours with some.
as long as you can connect the coaxial cable you should be sorted.
wipe area around original base with meths (will not harm paint) to remove dirt, wax, etc.to get good fix.
make sure you alighn it up properly before final fit.
