I have just imported a 2006 Verso into the UK from SA. The car was manufactured in Turkey according to the VIN plate. The vehicle has passed the import and MOT tests OK but I am concerned that I may have to change the engine coolant. The part number for the SA spec coolant is T 0888980089 and for the UK spec coolant is T 0888980072. The last two numbers are the key. Does anyone have an idea what the significance of those last two numbers are? Do I need to change my engine coolant out before winter arrives?
If you are really fussed about it you should change it. Toyota do extra longlife coolant which is pink (10year/100,000mile replacement)
This is what all Toyotas come with now.
Mart.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
