Toyota Avensis Auto Noise When First Pulling Away
Avauto
Hi, I own an 03 avensis 2.0 t3x auto. I've noticed when pulling away after first start up a crunch as if I've driven over something in the road. Doesn't seem to be due to the car being cold as even when warm if I stop turn off ignition re start and pull away I get the same. Trigger seems to be turning off ignition as if I stop the car let it idle in neutral or park then pull away I don't get the problem. Any ideas? Is this the norm as I haven't had an auto before?
Welcome to the club :thumbsup: .
You would get a response to your question if you posted it in the Avensis section as this is really just a self intro part of the forum.Hope you find out what the noise is :)
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
