My Rav-4 Jerks/does Hard Pulls (Tirones/jalones)
The Fainted One
Hi there.
I have a Rav-4 (1996) that is a superb trouble for me.
It is all the time producing jerks (jalones) when it has to go for a little climb or just when I accelerate the gas pedal.
It is not 4X4 as I know; automatic.
The car has turned off in broad movement 6 times endangering our lives.
The Fuel Pump (bomba de gasolina), the Fuel filter (filtro de gasolina) were already installed news.
But the problem persists.
What can be exactly the problem?
Please, help me.
I need to sell it this week in good conditions
Welcome to the club.
It sounds like something breaking down under load. I would look at the coil or connections to it.
Have a look at it in the dark and see if there are any blue sparks indicating a crack. The distributor cap if fitted is also worth checking.
Good luck.
Hi there.
It is all the time producing jerks (jalones) when it has to go for a little climb or just when I accelerate the gas pedal. I mean, it mis-fires jerks and splutters at low revs.
Please, help me.
Can be the Map Sensor?
Good luck.
Hello thanks u for the reply.
maybe...
what do u think about the map sensor? Can be it?
Yes it can be but the MAP sensor tends to make the car run poor (low power, hesitates) and components on the high tension electrical circuit like the coil or distributor cap tends to make serious misfire (*****, snatch). Some of your description of the fault is lost in translation and I am not able to understand your terminology.
I hope this helps.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
