1995 Rav 4 Aircon Component Questions
selsdon500
Can someone please help me with the following:
My car is a 1995 Rav4 with AC and need to know the following:
1) Where are the charge points ? I have found one running parallel to the top of the radiator with a blue cap but cannot find the other point.
2) I need to replace the condenser and drier. The condenser looks fairly straightforward but how on earth do you access the drier as it appears to be buried down below ?
Many Thanks
refrigerant is under high pressure and if you don't know what to look for on the ac system to find the high and low pressure ports then i would leave it to a trained operator also it will need to be drained of gas aswell befor you start
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
