2008 Rav4 Xtr D-4D
harrirav4
i have owned above vehicle from new.
there has been a pinching effect every time i use the clutch pedal.
items so far replaced under new vehicle warranty....
clutch assembly
flywheel
2,master cylinders
clutch bracket and pedal assembly.
i still have the same problem,that at certain engine/outside/interior temperatures...the clutch pedal pinches as i engage and release clutch.
my vehicle has how recorded just over 10,000 miles.
Hi and welcome to the club.
Can you add more detail to your profile so we can see what model you have.
Also, I don't quite understand your terminology. Can you describe what you mean by pinching. Do you mean it sticks down at the floor?
hi anchorman, i will put more detail in my profile,not quite use to this site!
i have a rav4 xtr d-4d 2231cc
i bought it from new august 2008
from new,i have had a pinching effect through the clutch pedal
the action of the clutch its self is smooth
each time i depress and release clutch pedal (if it was a clutch cable system) one would think,it's the inner cable catching on the outer cable.
i have been told by my dealer,toyota comanpy know of this problem,i believe there are 2000 vehicles that may have same defect.
about a month ago...my dealers replaced the clutch bracket assemly and the clutch pedal.
they were inrtucted bt toyoya to do this..modification.
BUT...i still have the same defect!
so in desparation...have placed my thoughts on toyota owners club web site...to see if others,have had the same!
regards rex....."harrirav4"
Sorry - what do you mean by "pinching effect"?
a gritty feeling when i press the clutch pedal down and up when changing gear.
Can you actually HEAR anything, like a bearing rattling, when you depress or release the clutch? And does that noise decrease when you depress and hold the pedal to the floor?
This might point to a dodgy thrust bearing, but if you have had a complete new assembly under warranty, one would presume that would be done also too forbye.....?
Clutching at straws,
Big Kev :(
I would also be looking at the muff bracket (yes folkes, this rather unfortunate name really does exist and refers to the tube on which the thrust bearing slides over the gearbox input shaft) and how well the thrust bearing fits.
Big Kev :(
hi..."toyota tech service bulletin"
adnormal clutch pedal feeling due to clutch pedal support misalignment!
my rav is in that range...my dealers ,have done all work recomended by toyota to correct the defect...ITS still the same,so in desperation...put it on this club.... rex :(
