Diesel Long Cranking Time When Engine Warm
Avensis2.0td
Hello, my 2000 2.0td avensis old 2c-te engine.
starts no problems 1st thing in the morning. but once the engine is hot, switched off and left for 20mins or so it takes alot of starter cranking time to get it re started. if i switch it off when its hot then immediately re start it fires up instantly!
something happens in that 20mins, like the fuel lines lose pressure? i dont know, but then if the engine completely cools down its fine so its a mystery. can anybody please help? thanks
Sounds it could be a fuel pressure problem to me as well.
(Pump / Filter ?)
