Celica Vvti 140 Door Ajar Problem
ledwards59
Hello all,
I am the proud owner of a fantastic 51 plate Toyota Celica VVTI 140, but the other day I was driving the car as normal and parked, got out and went about my day. I then went back to the car after about 30 minutes shut all the doors and looked on the dash by the rev meter and noticed it said I had a door open. I got out of the car open and closed all the doors including the boot, and then got in again. To my horror the light was still on. I thought probably best to inspect this when I get home. When I arrived, I again open and closed all the doors and the light was still there. I can now, not lock my car using the key fob and have to use the key to lock it. This is also draining my Battery.
Anyone had this problem before?
Hello all,
I am the proud owner of a fantastic 51 plate Toyota Celica VVTI 140, but the other day I was driving the car as normal and parked, got out and went about my day. I then went back to the car after about 30 minutes shut all the doors and looked on the dash by the rev meter and noticed it said I had a door open. I got out of the car open and closed all the doors including the boot, and then got in again. To my horror the light was still on. I thought probably best to inspect this when I get home. When I arrived, I again open and closed all the doors and the light was still there. I can now, not lock my car using the key fob and have to use the key to lock it. This is also draining my battery.
Hi
I had this problem and noticed that the door catch was loose just tightend up with a screwdriver and it cured it
