Diesel Starting Problem
jongy
I have a 53 plate Avensis Diesel that won't start. When turning the key in the ignition I am getting an electrical buzzing sound which cuts in and out and seems to be coming from the fuse box under the bonnet.
The engine is not turning over at all when I try to start it; it's completely dead. The Battery appears ok - headlights are not dimming when ignition turned, etc. I'm wondering if this is something to do with the glow plug fuse or relay. Can someone point me in the right direction? Thanks.
Quite possible the ignition switch is faulty, the part on the back of the key/barrell, quite common on Avensis
Kingo :thumbsup:
Hi jongy,
To me, it sounds like your starter motor is dead. It's located on the side of the engine fly-wheel. So you might need to replace it.
Dead glow plugs won't stop a car turning over when you turn the key in the ignition. Or as suggested earlier, the ignition barrel might need to be replaced.
