Changing Brake Light Bulbs.
I have an 06 Aygo which needs the offside brake light bulb changing. In every other car I've ever owned, this has been a doddle, but I'm damned if I can work out how to do it in this Aygo. Any ideas please?
Images from my manual:
The plastic wingnut is actually a normal nut M6, so you need a 10mm socket or wrench. With a small
socket set and a flexible joint you may be able to take off the ligt without removing the C-pillar trim.
