Draper Vacuum Petrol Pump Tester
toyotin
Hi there,
This is Toyotin. Does anybody have an idea how to connect a Draper Petrol pump/Vacuum tester to a Toyota Carina E Kudos (1997) 7A-FE Engine? Would appreciate any advice.
This apparently is to test the engine.
Draper Vacuum And Fuel Pump Tester
Suitable for testing and fault finding the following in petrol engines including:
Spark misfires; poor engine compression; weak /rich mixture; ignition over advanced /retarded; inlet manifold and carburettor air leaks; incorrect valve timing; poor fuel economy; balancing carburettors; turbo boost gauge; fuel pump testing.
