Avensis Tourer 2009/10 Towbar Problem
tomgilbert
Advice needed.
I have a swan neck towbar fitted by Toyota that has only 50mm clearance between the bumper and the towball on my Avensis Tourer 2009/10.
This is causing clearance problems when I have the car hitched to our caravan.
If anyone out there has a larger clearance can they give me the 3 long numbers that are on the top of your towball, please.
This will be very much appreciated.
Hello Tom
Not sure of your exact model but I tow with my 2009 (June) Avensis Tourer 2.0 Diesel TR.
I have an Al-ko AKS 3004 stabiliser fitted to both of my caravans,you may have the standard tow bar by the sound of it on your car.
IF you have a modern caravan with the above stabiliser 'will be too tight' as you discribe and you need to get an Al-Ko towball which has a 'longer neck' (the distance between the centre of the ball and the back of the towbar), the number ontop of my towball is AH 7081
Hope this may be of help.
Mike :thumbsup:
