Fuel Pressure Regulator
ajcluck
hi all, just received delivery of my fse fuel pressure regulator, instructions are generic, anyone got a useful link?
Once I discovered I was looking at the wrong end if the fuel rail it was pretty straight forward. However I am struggling to wire the fuel pressure gauge, how many wires can you feed off the cigarette lighter? Also what wire is it to tap into the ignition?
have you got a mutli-meter? just probe each wire and see which has a voltage after you turn on the ignition.
If it's only guages that you've got wired into the cig lighter then there's no real limit as they are all low load
