Gt4 Clutch Bleeding?
Azzam
hi, i have a GT4 carlos sainz celica GT4 and i have just put a Exedy clutch into it, now i start the car and cant get it into gear (i drained the clutch fluid). so im bleeding the system and its going well until i see no bubbles in the clear tube i lock up the bleed nipple, start it up and still wont let me into gear.
when i press the clutch HARD it will then let me go into gear, how can i remove any air bubbles that could still be in the system?
could be the rod under the clutch pedal needs adjusting ? lots of help here anyhow -----
http://www.mr2-tech.com/bgb/mechanical/volume2/clutch.htm
  • 2 months later...
