Corolla 98 Stereo
aqry
How can i remove stock cd-player(Panasonic TM4411?) from my corolla? No idea how to do it... Theres no help in manual etc. Ive tried few times but i had no freaking idea how does it come off =P
Welcome to TOC.
Do a search for head unit and corolla and you should find lots of info. I've done a write up here also - it's just waiting for you to find it here
Edited by ae111sr
Thx. Ok, im not very good in english :( I have to rip that freaking thingy off where the cd-player is? I almost did that already but thought "**** this is not right" :) thanks for ur fast reply. Ill post here when the "dirty" work is done :)
First you need to remove the heater vents in the front of the dash. Then remove the two bolts that secure the POD to the top of the dash. If you try to remove the POD without doing this you will cause lots of damage.
HiioHei! Finally i got my new CD-player on :) It only took like 4h to put it in work :) Removing that "pod" was easy but those god d*mn wires were hard. Had to buy new connectors etc etc... sadly, 'cause that toyota idiotic wiring, those lights where u can adjust heat etc doesnt work anymore :D ill look into that tomorrow
