Headlamp Replacement
Kryten
I know this topic is old now but I've only just got my 54 T-Spirit, I need to change the lamps due to the melting problem, does anyone know if a much later unit from a 57 or 08 Avensis (by which time the lamps were modified), will fit, are they all interchangeable or will the wiring connectors differ or simply will just not fit?
hi all the wiring are the same, headlamp will fit with a little modification
