Lean Error Codes
Tempesta
Hi all,
I was wondering if anyone could help me? I have spent about 2 months trying to figure out some problems i'm having with my Celica, but to no avail. Anyway, i shall explain.
I got the car put on a computer and it pulled up codes
P0171 (System too lean bank 1)
P0113 (Intake air temperature sensor 1 circuit)
P0100 (Mass or volume air flow a circuit)
So far I have done the following: -
Serviced
New MAF
New spark plugs
New air filter
Injector cleaner
Visual inspection of vacuum hoses (not sure I would of spotted anything myself though..)
Cleaned throttle body with carb cleaner
The malfunction light is on. If it is taken off it comes back on pretty quick. From a cold start the car idles up and down then starts to dip lower and lower till the car shakes tremendously and on one occasion stalled. After a couple of minutes it sorts itself out a bit. If I try and drive the car away before I let it sort itself out I basically have no control over the power and its jerks around like a wounded shark.
Even after its warmed up I can still feel problems. Its 'severely' down on power since this problem has started. Also, if I sit at a constant speed with accerator held steady I can feel the car slowing and speeding up of its own accord.
I really desperately want to get my car fixed as I love it and i'll never get rid of it. I just am running out of money to throw at it and still have several expensive suggestions to try out. I would be eternally grateful if anyone could give me their thoughts on this? And I don't post this question lightly, I have been to 2 garages, searched the web for months, and piled about £600 into getting mechanics to try stuff so far.
Things I still havent done or have seen suggested around the net: -
Pre-cat Lambda (although most people say they did this first and it didnt fix anything)
4 new Coils (a few people have mentioned this)
I hope I have explained this pretty well (i didnt know a single thing about cars until I started looking into this issue and trying to learn how things work)
Regards
Will
Celica Gen 7 ZZT230
Engine - 11ZFE
