Hey guys!!! i'm in a big jam here i've a 97 glanza v and its running rough. Now the car drives,runs and boosts when its cold but once the needle on the temp gauge gets have way there is no power at all and starts misfirein like mad.i'm after changing plugs,leads,mass sensor,cool temp sensor and turbo vacuam sensor but no use can someone help me cause i'm going mad!!!
Thanks guys
the ECU regulates the fuel delivery dependent on the coolant temperature, it sounds there may be a problem with it. is there a Fuel Cut Defender wired in or something similar? if not you might consider getting a second ECU to try it.
The car is bog standered just has a jazzy air filter. i tried an ecu but its the same i'll try another cool temp sensor in case my one is faulty thanks a mill cause my heads melted from it :thumbsup:
