hi i need to find a wire thats line when the ignition is turned on for ny new drls
a pic of under the bonnet would be great or the colour of wire ect
hope you can help me
If you're taking off the bumper, find the brown or green wire going to either washer pump.
Both are located behind the washerbottle, just in front of the righthandside front wheel.
I used the green wire to the pump for the +12V feed with ignition and the green wire
to the sidelight to turn the DRL off when you turn on the lights, as it is supposed to work.
wow thanks very much for that , pics too
thanks again
adam
