Owner Of A 2001 Landcruiser
gamlc2001
I am an owner of a 2001 Landcruiser I signed up for this board, because I am trying to fix my car problem. My car won't start. It has been happening for on and off for about four months. I have called AAA to have it towed down to the dealership. Once it is there, they have no problem starting it. I don't know what to do.
Hello & Welcome to TOC. :thumbsup:
TBH I think you'll have to provide much more information,(Prob best in a specific "help" thread.) as it could be a vast number of things.
I had an intermitent starting problem on an injection car of mine & it turned out to be a loose piece of rubber that kept blocking the fuel pump connection as the spring holding it in place had broken/dislodged. No amount of dealers could cure it & I came across it accidentally when I bought a used fuel pump wwith the "valve" assembly still attached so I took the old one off & bits fell out & it started first time every time,until my wife wrote the car off a few weeks later ! :crybaby:
