Yaris Verso
BobH
2001 Verso Automatic on a 51 plate.
Difficult starting when cold and very low lumpy tickover - OK when warm and performance seems unaffected.
Local Toyota garage spent 1 hour on diagnostics and found there was a fault code registered. They want the car back for a further 2 hours diagnostics(@£83 an hour) to check voltages etc and then the fault could be anything up to a new ECU.
If it is relevant the fault appeared after the Battery had been changed.
Has anyone any ideas of possible fault please.
Sounds like : mixture enrichment not happening when engine is cold.
Obvious candidate: temperature sensor...
I assume it was tested?
