24 Led Lights ( Fit In The Headlight)
Gasty
Hi All,
im New to the forum.
I recently bought the audi style LED lights to fit into the headlight. Does anybody no how to take the headlight out and how to attach the led on the electronic side?
i have a Toyota Yaris 2001 1.0
cheers
Gasty
Hi All,
cheers
Gasty
If you want to fit it inside the lamp, your gonna have to take the lamp apart. Not easy as the 2 halves are bonded together.
Not sure if the lamps can be split, i wouldn't think they are designed to be.
To get the headlight unit apart, the only way of doing it is to bake it in an oven and then pull apart, and you will have to re-seal it later.
