Interior Clock
Harbottle
Hi whenever i switch engine off/on (Avensis 2.0 d4d 2005) the interior clock reverts to 12.00 . Any ideas ?? no other electrical problems apparent. Thanks
Sorry was a bit wrong there no interior lights either ?
  • 1 year later...
hi sorry cant help you but i have the same prob if you get it sorted could you let me know and i will do the same thnx
Have you tried removing the earth lead on your Battery for a couple of mins as this may help to reset things,though you may lose some of your settings on the radio etc. but worth a try.
Sounds like a blown fuse. Interior light and clock run off same fuse. Has your 'lights on' buzzer also stopped working? I had same problem (2007 Avensis) caused when I tried to change interio light bulb with switch 'on' position. Fusebox is located under dash to the right of steering column.
Hi
Agree with last post try 7.5 amp dome mini fuse located in fusebox under steering wheel
