Pick Up My New Iq Sun
Getting my first iq2 on sunday Its a 09 with 12,300 on the clock. have not seen the car as yet and have not driven it, any advice what i should lookout for before i had over the full money
thanks
thanks
Is it being bought privately or trade??
thanks
Thanks for your reply
Its trade
thanks
Its trade
Make sure it's had its first service. It may well be overdue by now.
thanks
I would check to see if the trip computer has been changed to fix the "not reading over 60mpg" problem.
If not get it booked in to be done, it is a recognised fault that has to be rectified but not all previous owners have had it done.
Hope this is not too late before you pick up the car.
thanks
Another thing that occurs to me is the inside panels are prone to getting scratched/marked and if you have not seen the car that could be the case in yours.
I wouldn't pay unless they are willing to change any badly scratched or marked panels.
Have a good look inside!
thanks
Thanks guys . i will let you know how it goes on monday
thanks
We had the mpg "fix" a couple of weeks ago by Mr. T at Gatwick and I noticed an immediate improvement in the mpg estimate indicated in the display. The milage on your car suggests to me it has not been replaced as the odometer will be reset to 0 and the dealer should have that stamped in the service manual. If it has not been replaced ask them to do so.
Hi
Et42 offset will fit
Dependent on where you are getting the wheels just get a trial wheel put on the vehicle first to see the look
You can fit anything from et38 to 42 on the iq and at the back of the alloy wheel you just insert the "spigot" which is a plastic ring which enables centralisation of the wheel to the hub
Another alloy wheel I would advise you to consider is the poison alloy wheels they look really good on iq
