Carlos Sainz Tuning
Carlos 1450
I was wondering if anyone out there knows anything about fitting a super chip to my car. Some say an FCD (Fuel Cut Defender) is the way to go. Please Help
Superchip basically equals fancy ***** fuel cut defencer and relief valve rolled in to one. check out www.k1ano.co.uk
FCD off that site and a relief valve will be a lot cheaper an probably yield as much power. Save chip mods until you have done a fair bit and need a dastek or stand-alone ems to cope with the new parameters.
if your going to mess around with boost levels then get a proper boost guage(unless you already have one) and dont go too high with boost level.
well motec is the best and probable the most expensive way to go, it has plenty of zones for those techies to play with and there are some extras that motec make which also cost alot that will help.
