After Market Cat
timson
We have just had the cat replaced, due to the pipe splitting.
The orignal sensor was put back. All was well for about 3 weeks, now getting error code description cat efficiency below threshold.
Cleared code and it came back on about a week later.Just happened again after a week.
Both times the petrol tank was very low [range 20 miles]
Any ideas and can anyone give me the resistance readings for the sensor. Thanks
The car is 2001 1.8 vvti ...
The attached picture is from the T25 Diagnostics guide, and may be different on yours.
Use at your own judgement....
HTH
HTH
Thanks for the info, the code we have is P0420. Is this the sensor after the cat?
HTH
Apparently this error code can be due to the fact that if your engine burns oil, this can contaminate the cat, which reduces the efficiency and causes the error code.
HTH
HTH
HTH
Back to the top
