Avensis
NIMBLE
Hi all.
My Heater Blower isn't very powerful. The previous owner seems to think that it is something to do with a Cable coming off on the Blower Dial. However, when you turn the Dial from Low to High you can hear the Blower increase in power. Is there more than 1 Cable attached to this Dial and does this sound like a feasible fault diagnosis.
Many thanks.
NIMBLE.
Hi all.
Many thanks.
NIMBLE.
Hi
Try cleaning the pollen filter, if this is blocked you will get exactly the low air flow you describe. The pollen filter is located behind the glove box, takes 10 minutes to take out the glove box clean/replace the filter and refit glovebox. Gotta be worth a try
Hi Tony.
Thanks for your reply. I like the sound of your suggestion and does sound perfectly feasible. I will give that a go and post a reply. Unfortunately it won't be tomorrow, other commitments.
Many thanks.
NIMBLE.
Hi Tony.
Many thanks.
NIMBLE.
hi mate
yes it is the first thing you have to do before arising a claim against to the fan. he does his job but the filter does not :)))
Cheers/Igor
