My First 600 Mile Tank
johalareewi
Despite the cold morning starts, the Prius just gets better and better. When I filled up at the weekend, the tank trip meter flipped to 600.1 as I drove up to the pump. And I could only get 40 litres into the tank to refill it. :yahoo::toast::thumbsup:
even when i am doing 60mpg... the fuel light start blinking at about 470miles. could get 36.43L petrol in 10 miles later.... what sort of travel do you normally do?
Brilliant! Now that summer is back I'm looking forward to the same in mine. :)
Your lucky, i've never really had more than 450 miles on a full tank (short urban journeys = killer)
Journey started with a 300 mile round trip from Southampton to Leicester which used about half a tank (Prius mpg said 70, av speed 55mph) was doing 65 to 70 most of the time. That was when I thought I a 600 mile tank was on. The rest of the week was normal commuting which usually gets 70mpg but I was helped by a massive 85mpg run one morning. Traffic has been a bit heavier than usual (kids back at school) so the speeds have dropped a bit but this is good news for me in the Prius because the mpg goes up :)
When the last fuel gauge pip started to flash, I had done 550 miles so knew I could get to 600 before filling up. I usually get over 500 miles from a tank with normal use and current mpg is around 60 so a 600 mile tank was a possibility.
Think the cooler weather will start to bring down the mpgs. :(
If my maths is correct that's a 30 mile commute in one direction. I think your mpg is amazing given the speeds you say you were doing, still you must really have got into the zone of how to drive the Gen 3 efficiently. :toast:
I was surprised too. The daily commute is more of a low speed, nose to tail affair with a short burst of motorway in the middle and I can now get 60mpg easily. The impressive bit was the run to Leicester and back. I was trying out pulsing and gliding so maybe that is what did it. Normally, I try and keep a steady speed but this time traffic was light so I had a go at P&G. It's a bit weird with the speed going up and down!
I am still getting used to driving a hybrid but fuel consumption appears to be improving each fill up! I still had 3 bars remaining on the display but didn't want to run the tank too low so filled up last night after 430 miles and seem to have got 60.7 mpg.
I have driven another 30 miles today and the fuel computer reckons 70mpg ! Doubt I will keep that up though!
Wish I had the Gen 3 for even better figures!
