Previa owner with a problem, any ideas????
P Reg Previa, 2.4 Auto. Brought mid August and worked great until this last week. Warning light cam on and car spluttered and stalled. Restarted fine and off I went. Since the the problem has gotten worse to the point now where it will stall at 95% of junctions and will not restart until it is left for 3-5mins. It will also 'miss fire' at times when driving on a straight road. If when running you can travel with revs over 3000 it seems fine, anything below that is likely to cause a problem.
To add insult to injury, I took it for a full service and was told that there is no power to the diagnostic connector, so that solution is a problem too!
Help!
  • 4 weeks later...
Help!
Phone Steve 07930 748513. He is in Wickford in Essex and I had a similar problem on the same model and he fixed it.
  • 4 weeks later...
Help!
Chek master cylinder. May lock up.
funny - mine runs ok but cuts out when going round a roundabout!! Just can't get to the cause of it at all!
