I've decided I want to change my stock ct-9 system for something with a bit more umph! In all honesty though I'm not very mechanically minded and I'm not sure what turbo would give the best performance. If anyone has any past experience of what turbos worked best for them or know by specs I would be greatful to hear from you.
Thanks.
I would also like to add from my new turbo I am really looking for break neck boost if you like if this helps anyone else helping me.
TD04 is the replacement turbo of choice, it'll work on the standard engine internals (with a little help from a piggy back ecu) provided you don't put too much boost through it.
plus they are cheap and readily available. only you can't just swap the turbo, your have to get a downpipe and manifold done as well.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
