Misfire?
alanstav
hi.i have an Xreg avensis 1.8vvti and the engine has just started misfiring/sluggish acceleration?it feels like when you used to have a spark plug/points fault on older cars,or could it be an injector problem?are these possibilities.
Hi mate unless you know they are new change the spark plugs and make sure they are the correct ones with the right gap as recommended by Toyota as I believe this is very important with this engine.
This is the first and cheapest option to start with then let us know how you get on after that.
Regards, Pete.
