Yaris T4D Stalling And Now Very Sluggish
carriefin2004
Can anyone help? I have a 2004 Toyota Yaris. The malfunction indicator lamp 1 is sometimes on for a whole journey then doesn't light up for a few days. Very random ~ Toyota garage said it was fuel system management and suggested a fuel filter change (3 years ago). I do get the filter changed regularly but still have light on / off. Today the light was on and the car cut out for no reason. After a few minutes I managed to restart it. 8 times in 180 miles, the last tem miles the car became very sluggish and I could only drive in a low gear. Relieved to be home ~ cherry on the cake ~ the cable snapped when I tried to open the bonnet.Car has done 118000 miles.
Any suggestions would be most welcome.
i had an identical problem with my rolla lad, turned out to be dirt in the tank being sucked up and clogging the pump.
i had it with 6 different crowds including toyota, in the end i had to get the tank cleaned out and new fuel pump.
oh yea, fuel pump from toyota - €2000.......fuel pump from Bosch - €350 :thumbsup:
Sounds like an injection problem to me. You may have blocked injector/s
Thank you ~ I will mention this to the garage.
Step 1 : change fuel filter.
Easy and cheap...
oh yea, fuel pump from toyota - €2000.......fuel pump from bosch - €350 :thumbsup:
Thank you ~ will definitely be looking for a non toyota pump
your fuel pump IS just a Bosch pump that toyota put a stamp on, :thumbsup:
