Breather Filter
ajcluck
Looking at getting a breather filter to replace the pipes which i currently have venting into the atmosphere. The filter will replace the pipe coming from the rocker cover, however what will happen to the other pipe that attaches to the breather box?
the one at the bottom is an intake put a 90 degree hose then a breather on it the other is the breather out which need to go into a catch tank filled with wire wool and a vent on it, dont forget to blank the holes in the rubber filter to turbo connection
