Rear Diff Lsd
mrbilly
which rear diffs, which are on later ravs fit the 4.1 (94-00). I think its upto 2002 but cant remember and which versions have the lsd i.e. vx nrg. can you tell by the vin plate it mentions the gearbox and if its man or auto. do any of you know if you have a lsd.
and i do mean lsd on the rear diff not the center diff.
thanks peeps
You are right . The NRG and VX of 2002 have a lsd.
could you send me a photo of your rear diff so i could see the fitment and the lower part of your vin plate.
do you know if the rear diff ratios are the same as the earlier ravs. on the manual ones
thanks
thanks
Interesting one as the 4.2 is a heavier car and the design moved away from the sports utility concept of the 4.1. from my little experience, I suspect the gear ratios are different on the 4.2.
