Windscreen - Deep Clean?
ashpole
I use Meguiars products and understand how to deep clean my bodywork. But what would I use to deep clean my windscreen to remove contaminants when in need of something more than NXT Glass Cleaner?
Cheers.
i usually clay mine when its bad, gets rid of pretty much most muck.
treat with rain x after to keep it cleaner for longer ;)
I use a liquid biological washing detergent. Dilute 50/50 rub it on and let it sit for 10 minutes or so and let the enzymes do the work of digesting the grease and grime. A good rinse off and then a final clean up and polish using Lidyl's glass cleaner finish with a scrim cloth when dry.:)
Thanks. What would I use to lubricate the clay?
Depends on the clay you get really. The ones we sell (see my sig) you can use just water to lubricate or you can get some of the berry blast detailer that you dilute down to use as a lube.
Sounds good, just didn't want to add to the problem by using something inappropriate rolleyes.gif
