last week put my car in to inspect a knocking noise from the front (i thought it was the suspension/hmmmm new coilovers :) ) but no it turned out to be a crack in the sub frame where the front anti roll bar attaches to it, well it seems well repairable about 3hours labour or so but the mechanic told me yesterday that there was another MR2 in with the same problem so beware :ffs:
cracked sub frame soudns nasty! :o glad to know its easily repairable...
Got some piccys,here is how the frame should look frameplok.jpg here is what it looks like (it has not been cut it has actually been broken out) frnoplate.jpg
on the inside of the frame there is a plate that the antirollbar connects too my mechanic says the plate is too small causing the problem (A design fault) platerollbar.jpgplaterollbar2.jpg
Have you seen anything like this mattmr2 ???
Got my baby back if you can’t see the pic's I posted last click this link it also has pic's of the repaired frame
SUBFRAME FIX
