Swapping Engine From 1.6 To 1.8 2003 Avensis
keane1
hi just wondering has anybody swapped engines from 1.6 to 1.8 on 2003 avensis. what sensors do you have to swap and what ecu's have to be swapped.I take it just the engine ecu and engine sensors,do you have to swap the crank timing plate.
I guess the easiest thing would be swapping the entire car for a genuine 1.8 one.
