1994 Or Later Not Running
tictoc4306
have 35 to 40 psi fuel preasure, map sensor was cleaned and is at 2.65 oms. has 5 volts on feed line and 12.75 volts on constent line. will run if fuel is added to throtal body with hand pump(squirt bottle) will run if key is held to start position replaced ign. switch- no change. thinking about possable lose of ground? or iac stuck open.
